I've got a '61 with the 283/230hp base engine. the car has been running rich and breaking up (lossing power, hesitating) on rides. I've checked ideal adjustment and fuel mixture and this did not correct the problem. Any ideas?
breaking up
Re: breaking up
Could be a number of things. Start with basics. Fuel filter, plug wires, points, etc.Tom Hendricks
Proud Member NCRS #23758
NCM Founding Member # 1143
Specialist for 27 years at BUDS Chevrolet.- Top
Re: breaking up
If the wires are old and brittle, I'd replace them. Look for burns or cracks in the wires. Pull one out of the distributor and make sure the ends aren't all corroded. You can surely tell if they are junk with a good visual inspection.Tom Hendricks
Re: breaking up
i ran the car lastnight and looked for arcing. and there it was...i'v got arcing between the positive and negitive posts on the coil to the middle of the coil. I tried to block it by putting rubber around the center of the coil, also tried around the two posts. but the arcing was still coming thru small gaps. should the coil be replaced?- Top
Re: breaking up
Can you see a crack or cracks in the coil where the coil wire fits? If not, I expect the problems are spark plug wires and coil wire.
At least replace the coil wire with a new one and see if that stops the arcing. Maybe with some dielectric grease on the outside of the coil wire post.
Verle- Top
