Does anyone have any experience in replacing the portion of the wiring harness in an early C-1 that extends through the body below the rocker panel and up over the rear wheelhouse into the trunk? I have a new harness that I'd like to install, but am unsure how to replace this portion. My restorer's initial idea was to tie a wire to the front of the old harness (in the under-dash area) and then pull the old harness out through the trunk area, dragging the wire with it; then attach the new harness to the back of the wire at the dash and pull through the new harness in the same manner. However, the old harness does not appear moveable (without the risk of damaging it).
Another idea has been to cut a couple of small holes in the interior fiberglass panels to gain access to the wire and help pull it through, and then patch these holes up later with fiberglass. Is there an easier way that we're simply missing?
Thanks very much in advance for any input.
