2818-1 Holley - NCRS Discussion Boards
2818-1 Holley
  • Frank C.
    • January 1, 1986
    • 277
    2818-1 Holley
    Hi all....from what I see in the archives, is it safe to assume none of these carbs were ever installed at the factory, in "64 or only over the counter replacements....Thx Frank
  • Timothy B.
    • April 30, 1983
    • 5177
    Re: 2818-1 Holley
    Frank,
    I believe the 2818 Holley is the production carburetor for 1964 high performance 350/365 HP engines
    • Donald T.
      • September 30, 2002
      • 1319
      Re: 2818-1 Holley
      For 1964 the 2818 would have been the production carb for the L76 (365 HP). It was used again in 1965 for the L79 (350 HP) and for the L76 (365 HP). The only difference for later service replacement carbs would be a post production 3 digit date code or any 4 digit date code. They also used different fuel bowl screws with later service replacement carbs.
      • Wayne M.
        • March 1, 1980
        • 6414
        If you mean the "dash-1" part; yes
        1964 model year should always be just LIST 2818. I have a 3A3 body (3rd week of Nov 1963) with no "-1" after the 2818.
        Mind you, I'm making a great assumption, as the 1965 TIM&JG says the changeover to the "-1" occured early in the 65 MY somewhere between 462 and 492.
