69 Frigidaire compressor - NCRS Discussion Boards
  • Roberto L.
    • January 1, 1998
    • 523
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 69 Frigidaire compressor
    Roberto I was going to tell you to go to Auto Zone and put down a deposit to borrow the tool to reinstall the drive hub. However I see from your profile you are not in the USA. I don't know the thread size of the front shaft.
    • Wayne M.
      • March 1, 1980
      • 6414
      Here's the Tool --- shaft is 3/8" - 24 thrds/inch
      Which is a standard (fine) thread. I took the bolt shown in the pic and threaded it both into the nose of the tool; and then the tool onto the compressor drive shaft, just to be sure that they were same thread size.
      The tool is "Robinair" from their 10500 series. It's the equivalent of Kent-Moore J-9480 and 9480-2. The ball-bearing collar rides between it and the large hex.
      • Roberto L.
        • January 1, 1998
        • 523
        Thanks Jim and Wayne, good picture, apparently the size is the same mentioned, 3/8" NF which means 24 lines per inch.
        Roberto, NCRS 30019, RMC
