63 dash pad removal - NCRS Discussion Boards
63 dash pad removal
  • Sander B.
    • March 1, 2005
    • 499
    63 dash pad removal
    hi i have started a boddy off resto on my 63 swc
    and started with the interior and now want to remove the dash pads
    but i cant figure out how these retainers work
    i tought i would better ask first before its to late
    best regards Sander,
    http://www.c2registry.org/index.php?...d=962&uid=3354
  • Keith M.
    • November 1, 1976
    • 205
    Re: 63 dash pad removal
    Sander,these are simple just push a flat bladed screw driver between the two metal edges and give it a good twist until the edges seperate from each other. As a general statement you will not be able to use these retainers as they have a tendency to break in half. If their is a tool out there that makes this easier I am not aware of it. I will be watching to see how other folks do it. Good luck with your car.
    • Tracy C.
      • July 31, 2003
      • 2739
      Agree with the slot screwdriver method. The clips are usually good for at least one reuse.
      tc
