I just bought the "ignitor" ignition system that allows you to replace your points with an electromagnetic setup. I also bought their 1.5 ohm coil. (I've been told it's a great replacement for the stock hardware). Problem is that the coil instructions say that the resistor between the ignition (key) and the coil must be removed (instructions for the electromagnetic hardware within the distrib says the opposite - go figure. I called the manuf and they said remove it..).
Question is where is that resistor ? '63 (mine is a '65) shop manual shows a resistor coming off of the ignition/key and says the resistor is "integral to the wiring harness". Sounds tough to get to ....? THoughts ?
Mark
Mark
