The turn signals flash slow on my 66 Corvette. The RH signal flashes maybe 1/sec and the left flashes maybe 1/2sec. The instrument panel turn signal lamp is out on the left side, but this should not affect flash rate. Front and rear signal lamps are all stock, electrical system is at correct voltage.
I may have the wrong flasher unit installed. Would appreciate recommendations on the correct flasher device and any troubleshooting suggestions. Also, is an electronic flasher available, which allows for adjustable flash rate or consistent flash rate? Thanks for all help.
