59 vette with holley card, no air cleaner?? - NCRS Discussion Boards
  • William B.
    • April 30, 1975
    • 939
    I just purchased a 59 (ex-fuelie) with the wrong engine and a holley carb on a gm intake. Can not get a regular air cleaner to fit, does anyone have any suggestions to use for now so I can drive the car?
  • Donald L.
    • September 30, 1998
    • 461
    Re: 59 vette with holley card, no air cleaner??
    Im using a drop down air cleaner base on my 62 from a 68 C-3 with a Quadrajet. I think a 66 C-2 drop down base for Holley would work. Might have to plug the vent for the valve cover.
    • Erich C.
      • January 31, 2007
      • 137
      Bill, do a on-line search for low profile air cleaners. Several companies offer them. I saw one that dropped the base 1 1/4" below the flange of the carb. They are about 45 dollars. Probably the least expensive way to go especially if its only temporary
      • Todd A.
        • February 1, 2002
        • 19
        Bill,
        I faced the same exact issue with my '58 a while back. I ordered a Mr. Gasket air cleaner MRG-6477. It has a drop base which fits no problem, and looks similar to the original carbureted air cleaner.
        • Christopher R.
          • March 31, 1975
          • 1599
          Believe you'll find that a 5 1/8" generic open-element drop down base air cleaner will fit. It did on mine. I just got a flyer in the mail from Jegs where they were on sale for $20 or $30.
          Wad up a ball of tin foil; put it on top of your carb; and, close the hood. The tin foil will compress to the amount of space you have. Deduct the drop down from the height of the air cleaner.
