Inside each door there are two places where the door is attached to the hinges. The fasteners for the hinges are metal plates with 6 holes threaded in them to match the hole pattern on the hinges. On one of the doors the threads in 2 holes on the upper plate need to be re-tapped. They are the front-most holes, and I am unable to get a tap or chaser aligned properly to do the job. The question: is there a way to remove the plate so that I can dress the threads on the workbench? The wing-vent apparatus is removed, and I can reach the plate with my hand, but I can't see the plate and I don't know how it is held in place.
Steve
Steve
