'69 Tranny Yoke
Re: '69 Tranny Yoke
The differential side yoke should have a round metal dust shield to protect the seal. This sounds like what you are talking about, but I don't know how it could come off unless you remove the yoke, which is retained to the diff carrier by a C-clip inside the diff.
Your second question is a little easier to answer. The axle halfshafts transmit much more torque than the driveshaft. Halfshaft input torque equals driveshaft input torque times the ring and pinion ratio.
Duke- Top
Re: '69 Tranny Yoke
Don, If your splined yoke has a hole thru the center of it the round plug was pressed fit to keep the lubrication inside the tranny. Most splines are cast with a blind core, thus eliminating the need for the plug.- Top
Re: '69 Tranny Yoke
Gene,
That was my question. So I do need this "plug" to keep in the tranny fluid. Do you have any idea as to how this could be re-pressed on or is there any type of "new" plug that I could get pressed on? Or, I'm I looking at finding a "new" yoke? The original piece that fell out was just a circular, slightly concaved piece of steel.
I drove it about 100 miles this weekend, I didn't notice any puddles of tranny fluid (yet). I'll pull the drive shaft this weekend and get a close up look.
Thanks, Don- Top
Re: '69 Tranny Yoke
Ten years ago, I had that plug fall out on a ride back to Moline, Illinois, from Buffalo, New York. The oil came out on the trip and the bearings had to be replaced. If you have the original plug, hammer the concave out of it with head gasket cement on the edges IF the outer (bearing) surface is smooth AND the splines are straight. Otherwise, a new (expensive) yoke is cheap insurance on your bearings. - Dave- Top
