Re: Addendum
Brandon-----
I'm pretty sure that the one you took off is the correct one. However, I'd greatly appreciate it if you would perform the little procedure I described previously. It would help me confirm if it's original and also provide other information that would be useful. It will just take a few minutes to wire brush the stud threads and check it with the 3/8-16 nut.
Also, the stud does go on the forwardmost, left (driver) side, exhaust manifold bolt position, but only if the car also has power steering.
No french locks were used for your application. Also, no washers, lock or otherwise, were used on LS-5 exhaust manifold bolts.
Brandon-----
