Hot Foot in an L68 - NCRS Discussion Boards
Hot Foot in an L68
  • Rick #47776
    Hot Foot in an L68
    New member here with question about hot floorboards in my '69 L68 convertible. Do the thermal floor liners found online work to reduce heat in the footwells? Anyone have a suggestion on which ones or where to buy them? I assume it makes sense to replace the jute underpadding at the same time? Existing is a bit ratty and Bloomington Gold (perfection)is not a top objective here. Thks.
  • Michael W.
    • April 1, 1997
    • 4290
    Re: Hot Foot in an L68
    I've always found that the #1 source of hot feet is flow of air (hot air!) through the heater ducts. #2 source is missing or damaged grommets in the firewall
    Relatively little heat actually transfers through the floorboards, padding and carpet.
    Bloomington Gold? Wrong club I think
    • Stephen L.
      • May 31, 1984
      • 3148
      Additionally to above comments... new jute will have some insulation properties over the "ratty" stuff.... probably not significant improvement.
      Heat is a common problem with these cars......
      Heater shutoff vent seals are probably gone allowing hot air flow from the heater.....
      • Verle R.
        • March 1, 1989
        • 1163
        Mike,
        I respectfully disagree on heat transfer through the floorboards and transmission hump.
        Until I got serious about high quality insulation mine got pretty hot on long drives.
        One vendor advertises "ceramic" insulation. It is about 1/8" thick so will fit under other insulation you might use and it works.
        Verle
