C-4 Hood attached wheel covers - NCRS Discussion Boards
  • Ed H.
    • November 1, 1999
    • 626
    I had my 93 Judged last week, in Leavenworth Wa. I had a question asked that I have not been able to answer. The 93 manual Vol. 1 shows the inner fender wheel covers are attached to the hood, by a 5.7 Mn (51in/pds) bolt or screw. The head looks nothing like anything I have ever seen. It appears to be a rivet but the manual calls it a screw or bolt. The head has a round inset with 3 slots spaced around the screw or bolt. Can anyone tell me what type of tool is used to remove these screws or bolts.
  • Tom H.
    • December 1, 1993
    • 3440
    Re: C-4 Hood attached wheel covers
    I believe they are a form of rivet. I think the tool you would use to remove them would be a drill !
    Tom Hendricks
    Proud Member NCRS #23758
    NCM Founding Member # 1143
    • Joe C.
      • August 31, 1999
      • 4598
      Ed,
      Can you post a picture? Early C4s, like my '85 use black oxide, round head torx machine screws.
      Joe
      • Ed H.
        • November 1, 1999
        • 626
        I went to my local Chevy dealer on 9-20-07. Their C-4 expert looked at the items and advised the items were rivets. He said the change took place in 92 or 93, and possibly were made on the ZR-1's. For some reason I don't think he was aware of any running changes made in the 90's, and might not be the expert he thinks he is. I need an answer from somone out there, that is positive on these screws, bolts or rivets.
