1964 frame serial number - NCRS Discussion Boards
  • Mike M.
    • August 31, 2006
    • 23
    I have the body off of my 64 and was expecting to see the serial # 4S122991. The 4 being the model year and the last six digits matching my VIN (which they do).
    However, what I see stamped on the siderail and on the left rear rail is S1122991.
    Anyone know if this sounds correct? Everything I've read says the model year number should appear first....thanks
  • Harry Sadlock
    Re: 1964 frame serial number
    The S is correct for a 63, I would guess that's it is also correct for a 64.
    Harry
      The model year designator didn't appear in the frame VIN derivative until 1965.
      • Mike M.
        • August 31, 2006
        • 23
        Ok, what is the meaning of the additional "1" in front of the six serial numbers? thanks
        • Harry Sadlock
          Mike, please doublecheck the stamp on your car. It should be an S followed by 6 numbers.
          Harry
          • Wayne M.
            • March 1, 1980
            • 6414
            I thought they only made 22,229 '64s *NM*
            • Harry Sadlock
              Re: I thought they only made 22,229 '64s
              The first (1) is a place holder, the same as in the VIN. Look back at your post I think you have 7 numbers after the S.
              Harry
              • Mike M.
                • August 31, 2006
                • 23
                Yes, 7 numbers - 1122991.
                • Tracy C.
                  • July 31, 2003
                  • 2739
                  Double stamp?? Post a Pic if possible *NM*
                  • Jim P.
                    • August 31, 2003
                    • 89
                    My 64 frame is stamped: S103935...same as the vin. There is no model year.
                    • Anthony F.
                      • December 1, 1985
                      • 191
                      John,
                      I can not remember what year that I was inspecting the Chassis line inspection station but I know that I got into HOT WATER because I left off a "1" prior to the "S" in the frame stamp. I guess it must have been on C-3's that I was over there.
                      Then the "S" in the stamp stood for St. Louis.
                      Tony
                      • Mike M.
                        • August 31, 2006
                        • 23
                        Sorry, everything's fine. On second look my guy tells me the number is S112291. One 9 in the number, not two. Poor communication on my part. Thanks for the input though.
