I recently discovered that I have a brake fluid leak on my '66 327cid, front left wheel. The leak appears to ooze out around the outside pad when I apply brake pressure. Since I'm going to need a rebuild or repair how do I identify the caliper as either OEM or correct replacement, and can I get rebuild parts at an aftermarket supplier?
Thanks in advance!
Thanks in advance!
