C2 Hood Clearance - NCRS Discussion Boards
C2 Hood Clearance
  • Kenny Hancock
    C2 Hood Clearance
    Can anyone tell me if a 1970 LT-1 intake manifold will fit under a C2 small block hood? How about the current Ram Jet electronic fuel injection setup? Thanks.
  • Norris W.
    • December 1, 1982
    • 683
    Re: C2 Hood Clearance
    I'm almost sure that the LT1 intakes were no taller than the L79/L76 intakes that were factory installed on the midyears.
    • Verle R.
      • March 1, 1989
      • 1163
      I suspect the Ram Jet plenum will fit under the hood.
      You may have to use a "droop snoot" air cleaner to fit.
      Verle
