Hello all,
After searching the archives last night, I found a post with excactly the same problem I had yesterday. Lost 4th gear and eventually couldn't shift at all. The shift lever just floped around. As I suspected and as a replying post stated, the pin holding the shift lever to the shaft that moves the linkage was gone. Unfortunatly the returning poster wasn't specific about what kind of pin it was. Is it a special Chevy part, or is it a common roll pin or bolt. If it is a roll pin what size, length, diameter is it. The 1/4" bolt with 2 locking nuts I put in there today seems to be working fine but I'd like to put the correct part in.
Thanks for your help.
John Araujo #43736
John Araujo #43736
