Head Light Mechanism - Lube? - NCRS Discussion Boards
  • Kirk McHugh
    Is there anything to lube on a headlight mechanism. My front left has started to hesitate the first couple of times I try and put them up, and then it seems to do fine (actually closing and opening faster than the right). But those first couple of times it really seems slow coming up. Is it lube or the motor going? Thanks.
  • Mike G.
    • January 1, 1991
    • 418
    Re: Head Light Mechanism - Lube?
    If you can't confirm that the motors have been disassembled, cleaned and lubed, then that's the most likely cause. But, I would first make sure you have a good ground connection at the motor support bracket.
    • Gary Schisler
      What year?
      • Kirk McHugh
        67
