I recently conducted a rod survey and found that Eagle has a new (for 2007) small journal 5.7" rod with either pressed or bushed small end. It's a 5140 I-beam type with 3/8" cap screws. The claimed weight in the catalog (you can down load the catalog in pdf) is 590 grams and typical Web price is about $250 for a set.
In the past I have had a somewhat negative view of Scat and Eagle rods because they are much heavier than the approximate 570 grams of the OE rods. For example, the Scat 2-ICR5700-200P (roughly equivalent to the above Eagle rod) was quoted at 660 grams over the phone by one of their tech reps.
The small journal rods tend to be heavy because they are typically machined from the same raw forgings as the large bearing rods, and since the big end has a smaller bore, more material is left on the rod.
In the past I have favored Crower Sportsman rods because their weight is closer to OE - about 590 grams, but they are about double the price of these new Eagles - and I still favor them for "327 LT-1" configurations, which can make useable power to about 7200, but for the new "Special 300 HP" configuration, these new Eagle rods are probably adequate if the 590 gram weight spec is true.
