I am trying to re-install the vent glass into the frame, utilizing the vent window mounting material from Paragon.
Can someone suggest the best way to get the glass/mounting material into the chanel ?
Should I use a heatgun to soften the material, or should I use a soap solution, so the material will slide better ?
I tried to get the glass installed, but the it will go into the channel only 1/2 way and stop. It bunches up at the corner...
What is the trick ?
Rainer
What is the trick ?
Rainer
