I am finishing up the chassis on my 66 (May '66 build) coupe). My question is in regards to the correct clip for retaining the parking brake cables at the frame and trailing arm points. When I took it apart (and this has proved to be a very original car), it had the horseshoe-shaped clips at these points. The AIM drawing looks like it also calls for the same horseshoe-shaped clips, but my 66 judging manual clearly calls for the mickey mouse spring clips as being correct. Can anyone clarify and advise? Thanks.
Larry
Larry
