Here's what I believe is a small block '69 clutch, of the Schweitzer(sp ?) design [bimetallic strip] dated 10.6.68_SC (Oct 6th 1968) on the flange edge (see link below). When I cleaned off the grime, the letters "CJ" appeared (see top of autoload pic). I understand from the '65 TIM&JG that flange dating started around mid (calendar ?) 1965.
I understand that "CK" indicates big block usage, and I have a few of the bimetallic coil design (Eaton) with this coding (but Eatons have no flange edge date coding).
On the one shown below and in the link, shaft and fan mating flange dimension to W.Pump pulley is 1.75", which I guess confirms the small block application.
There was another on eBay recently with a dating of 7.27.68_SD, also claimed small block application.
My question is what is the correlation between SC, SD and CJ, CK ?
