I have a 67 300 HP base engine and I'm looking into ways to increase power while maintaining a fairly stock external appearance (still trying to sort out what to do about "life after Top Flight").
On Duke's advice the heads were pocket ported while being rebuilt earlier this year. I also put in a cam that is roughly mid way between the 300 HP and 350 HP GM cams. Now I'm looking at possible improvements to the intake and exhaust flow. On the intake side, I'm thinking about changing to the 350 HP aluminum intake and "dressing" the engine as a 350 HP. I have a few questions about this that I'm hoping some of you can comment on:
1) Performance-wise, how much better is the 350 HP intake compared to the 300 HP intake?
2) Why does the 350 HP intake use a bypass connection between the water pump and the manifold, while the 300 HP intake (and most aftermarket intakes) do not?
3) Is there any harm in using the 350 HP intake with my existing 300 HP water pump and the bypass fitting on the intake plugged?
Assistance with any or all of these questions would be most appreciated.
