Parked car under normal conditions Sunday. Monday AM - stone cold dead. Found batteryshort on water (AZ summer), refilled & put on charger for 4 hours. Did NOT disconnect the cables. Tried again - still dead. Decided on a dead short as the culprit, disassembled car, removed 11 month-old battery and bought a new one. Before reassembling car, tried and car started.
Tues AM - stone cold dead; removed both cables, put short 3/8" bolt into the cable receptacles and installed the charger. After two hours it's up to 6 volts and climbing.
So where do start in the AM - circuit tester at the fuse block? Or? Any suggestions are welcome.
