C1 HIGH HORSEPOWER BALANCER - NCRS Discussion Boards
  • James O.
    • November 1, 1985
    • 160
    does anyone know the mechanical dimensions of the 3764318 balancer for 270 h.p. motors? there are 2 stepped diameters. specifically,what are the diameters and how wide is each step?.
  • James O.
    • November 1, 1985
    • 160
    Re: C1 HIGH HORSEPOWER BALANCER
    sorry, i did't think the first post went through.
    • Brad K.
      • August 31, 1990
      • 414
      My balancer (which is a Goat Hill repo) measures 6.05" dia on the outermost step next to the radiator and 5.05" dia. on the innermost step next to the engine. These measurements were taken from a pi tape. Incidently, both steps are milled from one piece of metal. The widths are 3/4" (outer) and 1/2" (inner). This stepped outer piece rides on a rubber isolator ring and mates with the center piece that's keyed to the crankshaft. The surface to which the pulley is bolted rides about 1/8" ahead of the outer stepped ring (toward the radiator)
      And....I have no idea as to how these dimensions compare with an original balancer. Hope this is clear.....Good luck!
      • Ed H.
        • November 1, 1999
        • 626
        James
        Brad is right on. I took some measurements off of my 57 Duntov 270b balancer, which was, 6", 5", 3/4", & 1/2", per Brads figures. In addition the generator pulley on the 270 is 3 5/8" in diameter, and 3/4" wide, deep grove (3/4" wide at the top). The belt rides deep in the generator and the top of the belt is approximately 3/8 below the lip of the pulley. As best as I could tell the belt is GM part # 3738487. It was difficult to see the numbers as they are pressed into the belt and not painted on. You might want to contact some well known restorers of C-1's, they might put you onto the parts you need.
        • Loren L.
          • April 30, 1976
          • 4104
          The ONLY Goat Hill repro that I have ever
          seen was 6 1/2" OD and with holes drilled throughout the outer ring, something that blueprint warns against doing. Are you telling me that he has improved his repop or is carving them from a different donor? The 6.05" OD sounds right on - now, where did I put that blueprint?
          • Loren L.
            • April 30, 1976
            • 4104
            57, 58 & 59-61 HP balancers are different *NM*
            • James O.
              • November 1, 1985
              • 160
              Re: 57, 58 & 59-61 HP balancers are different
              loren, yes, i believe they are different. to clarify , my question is related to 1959 270 h.p. judging from earlier posts and checking with outfits like paragon, the repro seems to have holes around the outside ring and 3 spokes in the center. this is unlike the picture and description in the judging manual.
              • Joe M.
                • February 1, 2005
                • 589
                Can anyone post a photo of a 59-61 balancer used on high horsepower 283 engines?
                There is a one sided photo in the Paragon catalog of such a balancer but not sure if it is correct. I have a couple of balancers that look like the one pictured in the Paragon catalog which came off, in one case, a 65 283 chevelle wagon. A picture would be a real help.
                Joe
                • Anthony F.
                  • December 1, 1985
                  • 191
                  Joe,
                  I basically ask the same question earlier this last month, as I wanted to "See" what a correct balancer looked like. You can find the posts in the archives.
                  I was directed to look in the 58-60 Judging manual and I would see a picture of the high horsepower balancer. To my dismay my OLD JM did not have the picture so I ordered a new one.
                  Not trying to sound like a smart a-- but If you want to see what they look like, the newer JM 58-60 will show you. This is where I found the picture I wanted to see. I hope that you already have a copy of the latest judging manual.
                  Tony
                  • Joe M.
                    • February 1, 2005
                    • 589
                    Thanks Tony,
                    I am surprised that with all the neat photos of obscure items, someone would have a shot of a balancer. Oh well.
                    Went through all the archives available before the request. The recent discussion and verbal description of the balancer created more questions in my mind that a photo would resolve. Especially between the paragon repro catalog photo and the, 'close but no cigar' 65/ 283 chevelle balancer I have for my 61.
                    Joe
                    • Brad K.
                      • August 31, 1990
                      • 414
                      I'm not very good at sending pictures but here is a valiant attempt! It may be too big, but here goes.....
                      • Brad K.
                        • August 31, 1990
                        • 414
                        Here another attempt.....It is too big and I've got to figure out how to reduce it. It's also fuzzy but you can kinda tell what it looks like. I WILL get better at sending photos!
                        [/IMG]
                        • Brad K.
                          • August 31, 1990
                          • 414
                          This one's is clearer....still haven't figured out how to shrink it! Anyone have suggestions?
                          [/IMG]
                          • Joe M.
                            • February 1, 2005
                            • 589
                            Super!
                            Thanks Brad!
                            So the stepped portion is one piece with the rubber ring seperating a spoked center piece. I wonder if the spoked center piece is common to the 283 chevy balancer and the vette balancer in your photo?
                            Joe
                            • Brad K.
                              • August 31, 1990
                              • 414
                              Joe,
                              I wasn't clear on the construction of my center piece. It is solid....with out spokes. I agree that the JG is incorrect, showing a spoked hub.
                              Brad
