I rebuilt my 66 base engine about 5 years ago. I ran the engine and car very little in preparation for flight judging that I sucessfully passed three times (two chapter and a regional). Following the Charlotte Regional in April, I decided to enjoy the car and drive it more. I have put over 100 miles on the car going through issues like Holley fuel percolation in the hot summer and a leaking Muncie countershaft that I fixed, and all was going well until I noticed some oil leaking along the bottom of the front of the crankshaft. It has gotten progressively worse and tonite, while on a lift, we were able to actually see torn pieces of the lip seal rubber protruding between the damper and seal.
When the engine was rebuilt I had to install a sleeve over the damper sealing surface because of severe wearing on the damper in the seal area. The sleeve was installed with the locktite cement and the lip seal lubed with oil. The damper has no mounting bolt on a base engine 327 but I advanced the damper to the same position as before it was removed by carefully tapping it with a hammer and block of wood. I am perplexed as to what may have caused this significant damage to the seal. The damper appears to remain tight on the cranshaft. I did paint this area with the damper on the crankshaft just like they did at Flint and you can see where the paint was worn away on the sleeve surface.
I have studied the Service Manual and it requires removal of the radiator and shroud on the 327 engine car, but the seal can be changed without removing the timing cover. I assume that you will need to pass a long bar through the grille or up and under the car to wrap the damper back on. Has anyone completed a timing cover seal replacement on a C2 small block with the engine in the car?
Kind of frustrated--
Dave Kitch
Dave Kitch
