C3 Caliper Bleeder Cap - NCRS Discussion Boards
  • john t wilson
    Did the original Caliper Bleeder Cap for a 1972 have a retainer ring to hold them on to the Caliper when they were pulled off the bleeder screw or did the whole cap come off? I guessing they were black.
    • 15573
    Re: C3 Caliper Bleeder Cap
    I don't think there is cap on the 1972 caliper bleeder originally -- however it is a good idea if you are going to drive your Corvette very much.
    • john t wilson
      Thanks for Info . Currently I do not have any installed but I will pick some up to keep the bleeders clean.
        john-----
        None were used originally.
          • May 31, 2002
          • 169
          John T from John O. No caps on my car. I suggest silicon brake fluid.
          I used it in late 1970's and it still works like a rock. You must flush
          whole system first. I used denatured alcohol to flush. If it isn't to late
          I also have the stainless steel caliper inserts.
          Big John
