C5 keyfobs need reprograming after Bat. disconnect
  • Ray G.
    • June 1, 1986
    • 1184
    Hello;
    Is it normal to reprogram key fobs after disconnecting the battery on C5s ?
    Make it a practice to quick disconnect batterys on everything but daily drivers.
    Thanks for your help.
    Ray
    I hope you dance
  • Alan T.
    • June 1, 1992
    • 87
    Re: C5 keyfobs need reprograming after Bat. discon
    Ray, I have stored my C5 for long periods over the past few years. Sometimes I leave the battery connected and use a Battery Tender, other times I have just disconnected the battery. Whenever I reconnect the battery, I have never had to reprogram my key fob, it works just fine.
    • Tom H.
      • December 1, 1993
      • 3440
      You should not need to reprogram them, but you may need to "relearn" them. It's easy. Take your keyless remote and stand next to the car. Take the first remote and hold the lock and unlock buttons down at the same time for 20 to 45 seconds. You should hear the horn "toot". Repeat with the second fob. Magically, they will work again. Try it and let me know if it works !!
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
      • john daly
        Ray,
        Here's the info from the service manual for a 2004....hope it helps
        john
        Transmitter Programming
        Each transmitter has a unique Vehicle Access Code (VAC) that changes every 5 seconds. If a transmitter or receiver is replaced, each transmitter must be programmed to the vehicle's receiver. Entering a specific button sequence on the DIC, up to 3 transmitters can be programmed into the receiver. After programming the transmitters to the vehicle, the receiver will update this code every 5 seconds in order to match the code programmed in the transmitter.
        The transmitter may not communicate or become out of synchronization with the receiver if any of the following situations occurs:
        The transmitter battery is disconnected.
        The vehicle battery is disconnected.
        The transmitter and the vehicle are separated for 2 weeks or more.
        The receiver is disconnected.
        Perform the synchronizing procedure if the transmitter does not communicate or becomes out of synchronization with the receiver. If the transmitter and/or receiver are replaced, preform the following programming procedure:
        Programming Transmitters
        Turn the ignition to ON.
        Turn the radio to OFF.
        Press the RESET button on the driver information center (DIC) in order to clear any IPC warning messages.
        Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
        Press and hold the RESET button for 3 seconds.
        Press the OPTIONS button until FOB TRAINING message is displayed.
        Important
        If the FOB TRAINING message cannot be display, check if the BCM is configured with the correct RPO codes.
        Press the RESET button in order to begin the programming sequence. The message HOLD LK + UNLK 1ST FOB will be displayed.
        Simultaneously press and hold the LOCK and UNLOCK buttons on the first transmitter for 15 seconds. The IPC will indicate when that transmitter is programmed and when to proceed to the next. Repeat this procedure for each additional transmitter or press the OPTIONS button to exit.
        Programming Cancellation
        The receiver will cancel the programming sequence if any of the following conditions occur:
        The program mode is exited through the DIC.
        The ignition is turned to OFF.
        The three transmitters have been programmed.
        The RFA system has been in the program mode for longer than 2 minutes and no transmitters have been learned.
        If the program mode is cancelled with less than 3 codes stored, the receiver will only accept the codes just stored. If the program mode is cancelled before any code is stored, the codes still remain valid.
        The receiver retains all current access codes in memory if either of the following conditions occur:
        A programming sequence is interrupted.
        The battery is disconnected.
        Synchronizing Transmitters
        Preform the following procedure if a transmitter cannot communicate or becomes out of synchronization with the receiver:
        Move a programmed transmitter within range.
        Press the LOCK and UNLOCK buttons on the transmitter simultaneously for 7 seconds.
        The horn will chirp once when the transmitter is synchronized. Repeat this procedure for each additional transmitter if needed.
        • Dennis C.
          NCRS Past Judging Chairman
          • January 1, 1984
          • 2409
          That also explains why I like my '62... *NM*
          • Ray G.
            • June 1, 1986
            • 1184
            Re:Thanks everyone!! keyless entry on a '62 ? *NM*
            I hope you dance
