70 BB thermo housing - NCRS Discussion Boards
  • Joe B.
    • January 1, 2003
    • 14
    I have a 1970 LS-5 w/AC that has a rough finish thermostat housing on it. I also have a spare housing that is marked GM 3877660 on the neck? What is the correct application?
    • 43193
    Re: 70 BB thermo housing
    joe-----
    Any thermostat housing which has no part number embossed anywhere on it is NOT correct. The 3877660 is the correct housing. However, the configuration of it changed a bit over the years of its availability. The correct version will have small casting "wells" on either side of the base section.
