C - 1 Tachometer Info Requested - NCRS Discussion Boards
  • Steven B.
    • January 31, 2007
    • 119
    What is the Tachometer Application that Yellow Lines at 6300 - 6400, and Red Lines at 6500, with part number "1586083" on the back of the tach? Was it distributor or generator driven?
    Steve
    Re: C - 1 Tachometer Info Requested
    Steve-----
    Is the number stamped in ink or is it some way embossed? I can't find any C1 tachometer of that part number. It may be that the part number is for something other than the tachometer instrument, itself, or it may be that it's a PRODUCTION-only part number (but, I doubt it). Most C1 tachometer instruments have a part number that begins with "154". See if you can find such a number on the unit.
      Steve -
      If the case hasn't been molested, it should be ink-stamped either "Reads Cable Speed" (generator-driven), or "Reads Twice Cable Speed" (distributor-driven).
