throw out bearing in a c3 - NCRS Discussion Boards
  • Jeff M.
    • February 1, 1999
    • 127
    can some one give me the correct length of the throw out bearing in a 71 big block, along with the correct length of the ball stud? I am replacing the centerforce clutch that is in the car, and i am at the end of the adjusting rod and wonder if i have the wrong length throw out bearing or wrong ball stud
  • Stephen L.
    • May 31, 1984
    • 3148
    Re: throw out bearing in a c3
    Did you install the throwout bearing on the clutch arm correctly? It should be in the groove... not clipped to it. Been there done that!!!
    Correct mounting:
    Incorrect mounting:
    • Harmon C.
      • August 31, 1994
      • 3228
      Jeff
      If you have the flywheel cleaned up I think you lose adjustment. I was using local auto parts store parts and the second complete set was fine. The first one was just like yours the rod was too short. If their is a way to measure the old and new parts and know what the results will be I would like to know.
      Lyle
      Lyle
        jeff-----
        The original clutch release bearing for a 1971 was 1-7/32" long. That bearing was discontinued from SERVICE more than 25 years ago and replaced by a 1-1/4" long bearing.
        The original clutch fork ball stud for a 1971 was 1-3/8" long. That stud was discontinued from SERVICE about 20 years ago and replaced by a stud 1-1/2" long.
        You will not find a 1-7/32" bearing or a 1-3/8" stud in reproduction or in the aftermarket. The 1-1/4" bearing and the 1-1/2" stud will work fine for your application.
        • Phil P.
          • April 1, 2006
          • 409
          joe, i have a short stud that is round at the pivot point,and the long stud has a flat at the pivot point---from what you have seen is this the norm ?, thanks,phil
            PHIL-----
            Yes, it is.
              The flat at the end of the stud is there to create as a small "reservoir" to maintain some grease between the stud and its mating depression in the fork.
