I have been told the best way to insure your tires are properly balanced is to have them dynamical/spin balanced and weights balanced on both the inside and outside of the steel rim, as required.
However, I have been told that earlier model Corvettes (1972 for example) did not have weights placed on the outside of the rim and were only placed on the inside.
Is this correct?
If so, was there a reason(s)?
What is the position of NCRS if weights are found on the outside of the rim during judging?
Any insight will be appreciated.
Jerry
Is this correct?
Jerry
