Warning: Undefined array key 5516 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
68 Protect O Plate ? -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
At the Carlise swap meet this weekend I purchased some Corvette books including a 1968 Chevrolet Owner Protection Plan booklet including the Protect O Plate. How can I verify if this is for a Corvette as compared to another model Chevy and what does the information mean? The information on the plate is: STD 978, T06051LR, P8H11, 194378S422808, FA0609W, and two digits one over the other R, 6, and then under those what looks like a small Chevy Bowtie. Thanks for your help.
194378S422808 is a 1968 Corvette coupe s/n #22808
Std interior = black vinyl
978 exterior color. Since I don't have my reference books at hand you will have to look that one up.
T0605LR = 427cid/435hp engine built June 5th at Tonawanda, NY
P8H11 = 4-speed transmission built H month (I don't know what month that is without my reference library. Transmissions have a very strange month code sequence, and we do not ordinarily judge the codes.), 11th day, model year 1968.
FA0609W = the differential code, built June 9 at Warren gear works.
The meaning of the remaining letter and number are dependent on their location on the plate. That can be decoded from your copy of the 1968 Assembly Instruction Manual (AIM). The other information is available from your copy of the 1968-1969 NCRS Technical Information Manual & Judging Guide (TIM&JG). You really ought to build a reference library for your baby. These books are available from the sponsor of this site. Click on the radio button at the top of the page for the NCRS store.
194378S..... indicates it is from a 1968 Corvette coupe. STD 978 seems to indicate standard black vinyl interior with International Blue exterior. That's all I interpret. There should be engine pad stampings, but I couldn't find the direct relationship for your car.
Regards, Kent Keech
Future Lung Cancer Survivor
Kent 1967 327/300 Convert. w/ Air - Duntoved in 1994 1969 427/435 Coupe - 1 previous owner 2006 Coupe - Driver & Fun Car !!! NCM Founder - Member #718
Terry the LR suffix code is listed for 427/435 model year 1969 and IR is listed for 427/435 1968 model year in the Corvette Black Book. The POP may have IR that was read as LR.
Sal ---- I suppose a nickname could be appropriate to accompany my signature. "Mr. Clean" has been suggested by my wife, but then, what does she know when it comes to cars and gearheads?
Best, Kent Keech
and Shingles Survivor
Thanks for all the great information. I will try one of the Corvette registry's and see if I can reunite this POP with the car owner. Any advice which registry would be best?
