I noticed that the JM says that the splash shield uses clutch head screws. My car (April 59) has hex bolts and they all appear to be original to the car (the car is very original, and the bolts are all the same, and covered in original looking undercoating). I also noticed that Paragon sells a splash shield bolt kit that includes the same kinds of bolts my car has. I am confused on if I should put my original-looking bolts back on or switch over to clutch head bolts to appeal to the JM. Any recommendations?
I also have a similar discrepancy with the Speedo and Tach cables. Both of mine are gray vinyl covered. They look almost identical in terms of age, and have the correct ends. In the JM, I should have a black Tach cable and a steel speedo cable. I also noticed that the speedo cable was changed to gray in 1960. Do you think they started using gray towards May 1959 (2 months before 60 build)? Has anyone else encountered this?
Dave
Dave
