1965 - Flywheel - NCRS Discussion Boards
1965 - Flywheel
  • Frank Ferrano
    1965 - Flywheel
    How many teeth did the standard flywheel for a 1965 small-block have? I'm just curious, what engines would get 168T and 153T flywheels? Thanks.
  • Wayne M.
    • March 1, 1980
    • 6414
    Re: 1965 - Flywheel
    Hi Frank --- All '65 Corvettes had 153-tooth ring gears. Your SB flywheel should be an "021" cast #. The 168 tooth ring gears started in '66 with the 14" flywheels.
    • Rick Dykstra
      Re: 1965 - Flywheel
      This couldn't be at a better time for me. I am wondering what the proper part number is for the flywheel for the '65 10.5" clutch as I am switching back from an 11" ,which is wrong for my car.
      • Frank Ferrano
        Re: 1965 - Flywheel
        Thanks Wayne.
        • Wayne M.
          • March 1, 1980
          • 6414
          Re: 1965 - Flywheel
          Rick --- 12.75" dia./153 tooth (ring gear) flywheel is GM part # 3791021 (both the part # as well as the casting #). There's a lot of them out there, as all '65's and earlier 327's used them. It appears that I'm in the minority in claiming that the 396 also used this flywheel, but with a higher rated clutch assy. Of course you'll want to get the right cast date (heh heh).
          • John W.
            Administrator
            • November 1, 1974
            • 5079
            Re: Message Board Help
            Sorry for the delay in getting a good reply to you. I was away all last week and didn't have access to my resources. I think I have found the solution to your Technical Discussion Board viewing. You are used to the Mixed Threaded Single Message-Style Listing. This style will list all threads newest at the top of the page. Each response will be listed under the tread indented from it's parent message. This is the classic default setup that you should have if you have never changed your preferences. In Preferences chose:
            List Style: Threaded
            Display Style: Single Message
            Sort Order: Mixed Order
            A newer style that I like is Mixed Threaded Guestbook-Style Listing. Just change the Display Style to Guestbook. This will open all of the messages in a thread in the lower window at once. This way you can follow the entire thread without opening message after message.
            Let me know if you have problems with this.
            Administrator
            www.ncrs.org
            • Tom B.
              • March 1, 1978
              • 720
              Thanks for the tip John. The guestbook style saves a lot of wear and tear on the old fingers.
              Tom
              • Terry B.
                • December 1, 1988
                • 111
                Why do I have to update "preference" everytime I go online? Is there a way to return to the index at the point that I was before viewing the thread? I am using the preference that was suggested with guest book and all threads being viewed at once.
                • Tom B.
                  • March 1, 1978
                  • 720
                  Good question Terry. I just came back in from my email notification and I'm still on guestbook. Maybe John knows.
                  Tom
                  • Art A.
                    • June 30, 1984
                    • 834
                    Terry, I tried to get the answer to that very same question, from John, a few weeks ago and we could not correct the situation---I still have to update preferences every time-----PIA.
                    Art
                    • Terry B.
                      • December 1, 1988
                      • 111
                      I believe I am in error. When I first go to the board, it comes up in a spit frame appearance that made me assume my preference had not been retained. I would immediately update my preference and continue. Instead,if I view one message and then return to the index, I'm in the full screen single frame mode. This appears to be correct. I should have just continued without updating my preference!
                      Now, how do I return to the index in the same position that I was before I viewed a thread?
                      • Art A.
                        • June 30, 1984
                        • 834
                        Terry, The only way that I have been able to get in the forum without frames-----and STAY in without frames, is------- AFTER you hit "set preferences" go down to " update preferences" and hit it. Then you will stay in "no frames" until you log off. The next time you re-enter the forum, you have to go thru the same process----Big PITA!!!!
                        It doesn't seem to matter that I have NO frames checked--?.
                        Art
