The carb on my 1965, L79 equippped Corvette that was recently rebuilt by one the well known rebuilders is experiencing some gasoline leaking out onto the intake manifold (both sides) after the engine is turned off. Not right away but maybe 30 to 45 minutes after the engine has been turned off. I have adjusted the floats per the shop manual, even lowered them to see if this made any difference, which it did some but did not completely eliminate the problem. I run the 92 octane BP premium gasoline in the car.
Is there another adjustment that needs to be made or is the some issues with surfaces not being flat or true causing the leaks or possibly things not being tightened enough?
James West
Omaha, NE.
James West
Omaha, NE.
