C3 Wheel Well Restoration Part 2 - NCRS Discussion Boards
  • Christopher J. Bunsey
    Can someone suggest what brand and finish (satin or flat) I should use when refinishing the inside of my wheel wells? The repaint overspray got underneath, and I want to refinish the area that was undercoated with the correct color/gloss Any tips or prep ideas?
    Thanks!
  • Kent K.
    • December 1, 1982
    • 1139
    Re: C3 Wheel Well Restoration Part 2
    Wheelhouse blackout should be the same as under hood blackout paint finish. Check the JG for what type of finish is expected.
    Regards, Kent Keech
    Future Lung Cancer Survivor
    Kent
    NCM Founder - Member #718
    • Harmon C.
      • August 31, 1994
      • 3228
      I use John Deere blitz black for blackout.
      Lyle
      Lyle
      • Vincent F.
        • August 31, 2006
        • 202
        I have same situation only I want to remove undercoating.Any ideas on this without the mess of grinding or sanding
        • Kent K.
          • December 1, 1982
          • 1139
          Use a heat gun and plastic scrapers. Have fun!!!
          Regards, Kent Keech
          Kent
