C2 Fan - I think. - NCRS Discussion Boards
C2 Fan - I think.
  • Robert T.
    • May 31, 1993
    • 346
    C2 Fan - I think.
    Can someone help me to identify a fan blade that I dug out of storage. It sure looks like a Corvette one. It has 5 flat head rivets per blade. Has Front, an H, and a W stamped on the hub. It has a 3" hole pattern and a 2 3/8 center hole. However it is 18" in diameter. That through me off. Can someone tell me what this is. Thanks.
    Bob
  • Tracy C.
    • July 31, 2003
    • 2739
    Re: C2 Fan - I think.
    Bob,
    Sounds like it might be a 66 fan for a C-60 Air car. The 63/4s used a similar animal for C60 except they had mushroom head rivets.
    A pic would be helpful if you can.
    tc
    • Robert T.
      • May 31, 1993
      • 346
      Thanks for the reply Tracy. I'll post a picture when I get home.
      • Peter L.
        • May 31, 1983
        • 1930
        Bob - I agree with Tracy that is sounds like a fan blade assembly for a C60 car. How many blades does the fan blade assembly have ?
        The 66-67 Corvette sb C60 fan blade assembly of the type you describe had 5 blades and has round mushroom head shaped rivets and while I find the FRONT and a "H" stamped on the front of the hub, I don't find a "W" stamped anywhere on the examples I have. The 64-65 Corvette w/ C60 fan blade assemblies is 18" dia and has 7 blades and the 66-67 BB w/ C60 an blade assembly has 5 blades and is 17-1/2" diameter.
        Is the area where the rivets are located depressed? If so, the fan blade assembly is the type used on 66-67 PASS and G10 vans w/ C60.
        Pete
        • Robert T.
          • May 31, 1993
          • 346
          With a little more accurate measurement,and with the aide of my glasses, it looks like this fan is really 17.5 inches. One blade is about 8 7/8, whereas the rest are 8 3/4 to the center. Thanks for the replys though.
          Bob
