C1 repro rocker panel support - NCRS Discussion Boards
  • James B.
    • September 30, 2005
    • 115
    I needed a replacement rocker panel support, and the originals in the car are aluminum. When the replacement came from Corvette Central, it was steel.
    Does anyone know if any other vendor carries the correct aluminum one? I need to repair a section and have no need to rip out the rest of the original to do the repair.
    Jim
    The 1959 Corvette Registry
  • Wayne P.
    • August 31, 1975
    • 1025
    Re: C1 repro rocker panel support
    Not sure what part you're looking for or year.
    • James B.
      • 115
      It's for a '59 (actually the part is the same from 57-62 from what I'm told), and it's the support that runs the length of the car under the door, embedded inside of the fiberglass.
      Jim
      • Wayne P.
        • August 31, 1975
        • 1025
        OK, I understand which part, but I have no idea where you are going to get it. Sorry.
