67 Brake Master Cylinder Rebuilt - NCRS Discussion Boards
  • Kirk McHugh
    I have an old original master brake cylinder that I would like to get refurbished. Any suggested vendors? Approximate price to expect? Already had the cap re-done and I just need the body of the master redone correctly for my 1967 327/300hp. Thanks.
  • Jeff S.
    • July 31, 1984
    • 383
    Re: 67 Brake Master Cylinder Rebuilt
    Kirk,
    White Post in VA. would be my choice. Ask for Billie & advise him that it would be NCRS application.
    • Bryan L.
      • June 30, 1998
      • 397
      $150 and you'll have it back in a week.
      BL
      • William O.
        • April 30, 2001
        • 355
        WhitePost...the best.
        • Chuck W.
          • May 31, 2002
          • 257
          Brake & Equipment Warehouse in Minneapolis. They sleeve with stainless rather than brass and they also warrant for use with silicone brake fluid. My experience with Billy has not been good with his standing behind warranty issues using silicone.
          On my Mustang K-Code he left out the forward master cylinder check valve causing a loss of brakes overnight. He blamed it on the silicone and would not warrant his work!? That was about 6-7 years ago, ever since then I've use B&E without a problem. They are also less expensive than Billy.
          I'd recommend doing some research on White Post on the AACA forum. They have documented numerous problems.
          • Chuck W.
            • May 31, 2002
            • 257
            http://forums.aaca.org/ubbthreads.ph...rue#Post201496
            http://forums.aaca.org/ubbthreads.ph...rue#Post284902
            http://forums.aaca.org/ubbthreads.ph...rue#Post198696
            • Brian K.
              • May 31, 2004
              • 358
              I would stay clear of White Post, I had a customer send a 69 Camaro master cylinder to be sleeved by them. It would not let fluid into the brake system after they where done, sent it back they returned it saying nothing wrong. I went out and purchased a cheap 20.00 NAPA master and had instant brakes, the customer ended up having to purchase another number matching master cylinder off eBay. White Post never would stand behind it or return any money, from this experiance I say BAD news and STAY clear! Sincerely Brian
              • William O.
                • April 30, 2001
                • 355
                White Post is one of the best, every part that I have sent them has been show quality that I have seen!!!!!!
                • Bert L.
                  • April 30, 1977
                  • 424
                  Has anyone out there had any brake component sleeving performed by:
                  Sierra Specialty Automotive located Quincy,Ca.? Curious because I have master cylinder work to be done and would appreciate feedback. web. address is
                  www.brakecylinder.com *Hello to all, this happens to be my first post ,although I have been member since 1978!
                  BERT
