Master Cylinder - NCRS Discussion Boards
Master Cylinder
  • Tom Ard
    Master Cylinder
    I just found my origional master cylinder in the Garage and it is off my 1960 vette. My question is where would be the best place to get it rebuilt?
  • James F.
    • December 1, 1985
    • 596
    Re: Master Cylinder
    Tom, Some may suggest White Post Restoration, I've never tried them. I have in the past had all my cylinders relined in stainless steel by Imperial Machine, Richard Suhr (402) 488 9450. I found his work always excellent. He used to advertise in Hemmings but doesn't do so anymore. I don't know if he still takes this type work on or not. Might call. Regards,
    • Kenneth S.
      • July 31, 1981
      • 302
      Re: Master Cylinder
      I had mine done by White Post and they did an excellent job. It works fine.
      • Chuck M.
        • February 1, 2002
        • 334
        Re: Master Cylinder
        I would recommend C.C.S.B. in Florida. They do incredible work and will have any brake parts that you need. The number is, 305-256-8077. Luke or Jeff will be able to help you. Good luck
        Chuck McGettrick
        • Dale Pearman
          WHITE POST
          Beware of White Post. Last set I got back was unwashed AND they forgot to drill holes in the sleeves. REAL ameteur job for high dollar. Also, I prefer brass sleeves to stainless because of the abrasive properties of stainless aginst rubber. The weight and relative inelasticity (inability to return to it's original dimension after a heat cycle) are also negatives in the use of stainless. Disc brake calipers are a different story. I would use stainless in that application.
          The Rev.
