1959 ignition switch - NCRS Discussion Boards
  • rick hendel
    I have a 1959 that I believe has a bad ignition switch. My quastion is how does the key switch separate from the ignition switch. I see the small hole on the crome key switch which I assume is the the way to separate the two. I just don"nt want to skrew it up if possible. Thanks Rick
  • Norris W.
    • December 1, 1982
    • 683
    Re: 1959 ignition switch
    You'll have to have the key in the switch. Through the small hole insert a straightened Gem clip. You'll be able to find the detent by feeling of it. If I remember right, you turn the key backwards. Don't force anything, just fiddle with it and you'll get the feel.
    • Dennis A.
      • April 30, 1999
      • 1010
      Best turn to the lock position, then insert the paper clip end into the hole, then turn counter clockwise...and the cylinder will release.
