54 trans side cover shift linkage drips - NCRS Discussion Boards
  • Brad H.
    • August 12, 2007
    • 724
    Where linkage fastens to side cover of tranny drip drip drip how to stop or just dont look at it? What up? Brad
  • Roy B.
    • February 1, 1975
    • 7044
    Re: 54 trans side cover shift linkage drips
    There is a felt gasket (seal) easy to replace or just look at it?
    • Brad H.
      • August 12, 2007
      • 724
      Ok, just got back Roy, I will check the shape of the old one or if it is even their and fix it. Thanks for even the small stuff. Brad.
      • Brad H.
        • August 12, 2007
        • 724
        Felt washer must go behind cap on shaft against shoulder at cover? Dont see any felt washer, where can I get one, any hardware store have what I need or can make one? Why are they felt, seems they would obsorb oil and then drip any way. Nut at shaft against cover only to slide this back to get to the washer or linkage and nut in between these two also, will this affect any adjustments? Thanks Brad
        • Brad H.
          • August 12, 2007
          • 724
          Any answers to my last response on the felt washer at left side cover? Brad
