1963 Vin Tag - NCRS Discussion Boards
1963 Vin Tag
  • Gene K.
    • August 31, 2006
    • 34
    1963 Vin Tag
    My Corvette Vin tag has 4 spot welds. 1 on the bottom left, and 1 immediately above. 1 on the top right and 1 immediately below. Is this correct?
    Thank you, Gene Kahn
  • Loren L.
    • April 30, 1976
    • 4104
    Re: 1963 Vin Tag
    As a general rule, NO. What's the serial # range? Does it show up with grinder marks (removing paint) where the spot welds occurred?
    • Gene K.
      • August 31, 2006
      • 34
      Re: 1963 Vin Tag
      The Vin Number is around 18290. No grinder marks can be seen on the tag. Thanks so much for your response, Gene
      • Tracy C.
        • July 31, 2003
        • 2739
        Re: 1963 Vin Tag
        Gene,
        The grinder marks would be on the steel brace that the tag is spot welded to. This clears the paint and primer for a good weld. Typically there is only one spot weld in the center of each end. If for some reason the spot welder was acting up or a new person was learning at the factory, a second pair of welds may have been needed if QA rejected the first welds.
        tc
        • Boyan B.
          • August 31, 1999
          • 187
          Re: 1963 Vin Tag
          I have seen several cars with 3 or 4 spot welds. If the first set didnt hold, the operator would pivot or move the spot welder to get a good weld. Not that uncommon.
          Boyan
