70 gas cap - NCRS Discussion Boards
70 gas cap
  • Mike G.
    • July 31, 2002
    • 709
    Re: Warren's got this part right
    can i just remove the red tab? is the cap the same except for the tab?
      mike-----
      1) As Terry mentioned, the cap with the red label is worth more than the correct one for your car, so I wouldn't suggest removing the label and ruining it;
      2) Notwithstanding the above, the caps are otherwise different with respect to embossments. So, removing the label won't get you the cap you need.
        • 15573
        #18
        Re: 70 gas cap
        I shouldn't post without checking the TIM&JG -- that will give the approximate range of the red-label gas cap. I will stand by my statement that the red-label cap in reasonable condition is more uncommon than the SEALED embossed cap.
          #19
          It's in the book...
          Your copy of the 1970-72 Judging Guide says, Interior, Section 9, Door Jamb Area:
          "...The top front of the door, forward and above the door panel, is semi-gloss to semi-flat black, the same color as the balckout in the engine compartment and under the hood."
          Note, there is no distinction on year of car or color combination...
          • Lyndon S.
            • April 30, 1988
            • 1027
            #20
            Re: It's in the book...
            What? what does that have to do with the gas cap on a 71?
              #21
              I put this reply on the wrong thread... It was intended for an open question a couple fo threads above. Please excuse...
