A 55 early engine , the Vett sat for over 30 years , I took the pic. Off some sight I found. %99 original parts. Few things shown is the early Radiator shrouding top piece has no cut out at the top radiator hose which is correct for early 55 , when it changed to have a cut out ? Not sure of the #.
Also early is the straight dash throttle arm, when it changed ? Around #400? Then they were curved to help clear the plug wires.
It also shown's the trans. And gas rods being bent original for all 55's. PG. Or 3 speed.
Heater shut off having finger pads ,not flat like replacements.
