Part # needed for 64 Harmonic Balancer - NCRS Discussion Boards
  • M W.
    • July 31, 2001
    • 835
    I am needing the correct part # for a 64 327 300 HP car. Any help is appreciated.
    Craig W.
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: Part # needed for 64 Harmonic Balancer
    Craig, My 53-72 parts book says:
    3896904
    57-65
    forged crankshaft w8 cyl (except sp H/perf, FI, 396)
    fyi: 3817173 is for the 62-68 sp H/perf, FI 327
    Rich
      Craig and Rich-----
      GM #3896904 is the one. However, keep in mind that this is a SERVICE balancer for the application and is not configured as-original. However, it will SERVICE your application perfectly and it's not real expensive. If you want original configuration, then you need to go reproduction.
      By the way, DO NOT use balancer GM #3896903 if someone tells you it's "the same thing". It does LOOK the same, but it's NOT the same.
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        Yes....I bought a 6904 many years ago for my 59, and it was not the same as my original.
        I needed a new one because mine came off the crankshaft while I was driving on the highway about 20 years ago. I heard a loud "thud", looked in my rearview mirror and I saw this orange thing on the road starting to pass me on the left! After looking for a while, I found it in the median strip while waiting for the flatbed to arrive. I never knew these were just a press fit and not bolted to the crank.
        Rich
        • M W.
          • July 31, 2001
          • 835
          Thanks all *NM*
