window adjustment - NCRS Discussion Boards
window adjustment
  • Ken B.
    • May 31, 2006
    • 233
    window adjustment
    Can someone give me some advise on how to adjust the side windows on my C-3 (75).After putting new weatherstripping they don't even come close to being right.Any and all help will be greatly appreciated.Thanks
    Ken
    Re: window adjustment
    Your copy of the Chassis Service Manual should have a section dedicated to the Corvette body as this was the only car in the line-up that wasn't Body by Fisher. Window adjustments are described there and there are basically four degrees of freedom you can address: Fore/aft to center in the door, in/out to align with the weather strips, rotation to square the glass and up/down stops. I'd get the book and read as this can be somewhat tricky with the different adjustments interacting with each other...
