C2 headlight bucket 1963 - NCRS Discussion Boards
  • Sander B.
    • March 1, 2005
    • 499
    i am now stripping all the paint from my 63 swc for over a month now
    and now stripping the paint off the headlight buckets
    and there is a area of bondo on the sides on both buckets see picture
    is this typical or should it not be there ?
    thank you again Sander
    http://www.c2registry.org/index.php?job=ShowWeblog
  • Harry Sadlock
    Re: C2 headlight bucket 1963
    Should be original, leave it there. Remember the 64 to 67 buskets were metal.
    Harry
    • Robert Jorjorian
      Yes .....agree with Harry ........it is correct............i
      Its panel bond not bondo as in plastic filler used in repairs.
      Its suppose to be there so leave it as you found it.rj
      • Sander B.
        • March 1, 2005
        • 499
        Thnx Robert and Harry for your answer
        i will leave it there just wanted to know it for sure
        • Loren L.
          • April 30, 1976
          • 4104
          Is this a fairly late car? Like 14,000 or
          more? I ask because of the side mounting for the headlight bezel.
          • Wayne W.
            • April 30, 1982
            • 3605
            Re: Is this a fairly late car? Like 14,000 or
            I would also say yes, but that does not look quite the same as original 63 bonding material. It was more brown in color.
            • David J.
              • April 30, 2004
              • 99
              This is a question. I am stripping my head light buckets on my 66 and I notice on yours the pivit is welded to the bucket, I can also see where one of the holes that would be uesd for the screw that holds the pivit is filled with weld. This is nothing like the ones on my car. It it the year difference ?
              • Wayne W.
                • April 30, 1982
                • 3605
                63s are totally different. They are fiberglass with steel structure. Yours is metal die cast and has screwed on pivots.
                • Sander B.
                  • March 1, 2005
                  • 499
                  Loren it is 11431
                  Sander
