1965 grounding straps - Question - Help! - NCRS Discussion Boards
  • Jerry DiTullio
    Hi,
    Does anyone have a picture or a clear description of where the grounding strap goes that is near the sill plate or the rocker molding on the left side of the car?
  • Eugene B.
    • May 31, 1988
    • 710
    Re: 1965 grounding straps - Question - Help!
    Jerry,
    I don't have a picture, but perhaps I can describe in words how it's installed.
    The strap is approximately 5 inches long. One end has a ring terminal on it, while the other end has a clip type terminal. The clip end is fastened to the bird cage near the bottom where the metal makes a 90 degree bend. This will be almost directly under the body mounting bolt. I can't tell how it is attached. Perhaps it is spot welded, or just an interference fit. (No bolt is used).
    The ring terminal end is secured to the frame/body mount bracket, through a hole that is threaded for a self-tapping style bolt. This is also pretty much under the body mounting bolt near the corner of the splash shield.
    I hope that I've done an adequate job of explaining.
    Good luck, with your '65.
    Gene
    • Rob M.
      • June 30, 1999
      • 171
      Here is a pic on my restored '65. I assume this is correct but can not confirm - maybe others can comment.
      My Project Pictures
      http://temp.corvetteforum.net/classics/l78vetteman/
      • Rob M.
        • June 30, 1999
        • 171
        still troubles with pictures - here is the url
        My Project Pictures
        • Jerry DiTullio
          Thanks everyone for the information. Your comments and pictures helped much...
          • Jerry DiTullio
            Rob,
            I even found the original screw still in the metal...Everything worked fine. Thanks again.
